Incredible as always.Those boxes are the real deal. great job!!!
Thank you Mike. Quote:
It's snowballed a little, Steve. I find it very easy to keep spending money on tooling, but I won't be getting a new machine until I wear this one out, or until I build a workshop for something bigger. Still, I'm very pleased with this machine. It wasn't perfect out of the crate, and took me a while to dial in, but it's totally worth it. Thanks for watching the progress.
Nathan Last edited by Espeefan; 03-19-2012 at 05:51 AM. |
Very nice start on a great project! If you want to go even smaller than the 0-80 machine screws you might want to try www.scalehardware.com He has nuts and bolts down to .5mm. He also has taps for that size. I have only had the nerve to try 1 hole in .5mm. Came out OK but very nerve racking as it was the final detail on the part.
LYNN |
Forging ahead! I got two more tread plates for the steps done this morning. ![]() Here's another photo, that shows how I hope to tie the steps to the boxes. I've got some step side members machined, that will pretty much bolt together, like the 1:1 steps will. These are not finished parts yet. The front edge (lip) will be milled off completely, at an angle, to match the 1:1 steps. In the next stage of machining, they'll be finished. Sometimes you have plan how you are going to hold onto such small parts, for each step of the machining process. They are oversized right now, but will get trimmed down to size soon enough. The top step will be slightly narrower then the bottom step and the side members will be angled to meet the top step. One just has to look at the 1:1 prototype photo I posted to see what I mean. ![]()
Nathan |
Nathan, the step plates look really great. A lot of drilling but sure adds a bunch to the detail. If the 0-80 is a bit large, maybe 00-90? I use this size a lot on brass, aluminum and styrene. Not really a problem, in my experience. Just take your time. I've had the best luck by holding both the work and the tap in my hands. Seems that both "move" together, as opposed to having the work stationary in a bench vise. I've never used a tapping block or fixture - perhaps they would be helpful. Keep up the good work!
Big iron is awesome! |
