You see there is three holes on each side of the swing motor. That is what the house main plate is attached to..
http://servocity.com/html/spg785a_top_mount.html The servo city drive I get at 6 rpm, then invert it, the gear is mounted solid to the undercarrage. greg |
Thank you so much for sharing that part, I have been scratching my head for quite a while on how to build the turntable. That part is perfect.
Thanks again |
Do you have countinius travel with that??
If you checkout my thread starting on #370 you will see how I built my continues rotation.. ( slip ring ) The wires come up through the centre shaft of the swing motor and then solder to the brass rings...
greg Last edited by RCLogger; 03-23-2012 at 08:50 PM. |
I mean does the kit from servocity have countinues rotation? or have you modified it? |
Continues
Currently Active Users Viewing This Thread: 15 (0 members and 15 guests) | |
