Old 09-08-2010, 12:29 PM
Thorsteenster Thorsteenster is offline
Thorsteenster is on a distinguished road
Default Re: Anyone use other than cap/phillips screws in builds?
Well I found MicroFasteners a few years ago, and ever since have really wanted to use the hex heads on something but not being metric I didn't want to have to worry about threading issues.
I'll be using them for building my Volvo'ish truck. My screw box is pretty scarce so I needed to replenish anyway to hold it together once I get going.
I'll use the M3 for main assembly, then get a better idea of needs and order some smaller sizes from MicroFasteners. I'd like to have all the fasteners "nuts and bolts".
Call me Thor, it's short for Thorsteenster.
In VA? Check out
Old 09-08-2010, 01:07 PM
tc1cat's Avatar
tc1cat tc1cat is offline
Super Moderator
You might want to try www.fastener-express.com for metric and SAE nuts and bolts. They have a very large range of sizes and types of materials used. Prices are not too bad either.
Old 09-08-2010, 01:10 PM
steamer's Avatar
steamer steamer is offline
Thor. I've used a company in Florida for small hex bolts for my steam engine. They are American Model Enginer Supply. Quite a slection of sizes, both steel and brass. Rob
http://www.americanmodeleng.com/id41.html
Old 09-08-2010, 01:23 PM
SonoranWraith's Avatar
It's a dry 115 degrees.
I use brass M3 hex heads, though I bought overseas. Really low head height of only 1.7mm. Some of the 3mm stuff I have seen still has a bulky head height. I also have 2mm acorn nuts for my wheels because I don't like the socket cap screws. I still use stock screws for stuff that doesn't show.
Pic is a little dark:
