Old 03-28-2012, 04:18 PM
RAIDERS RAIDERS is offline
Super Moderator
RAIDERS is on a distinguished road
Default Re: Aeromax Daycab Dump 6x6 (Update: 3/28)
Looking good.. how do those tires compare to the cross force tires.....
LARRY,the doggy dish dealer
Old 03-30-2012, 04:50 PM
Stepside's Avatar
Stepside Stepside is offline
Super Moderator
Stepside will become famous soon enough
Thanks for the comments guys. I appreciate it.
as for a comparison to cross force, I can't help out in that regard much as I dont have any on hand. I believe the cross force are softer. These tires are very close in height and width to the stock tamiya tires. They are slightly stiffer also, I think because the walls seem thicker. it seems that they are wedged into the channels on the rims where the bead seats; the tamiya tires fit completely in the bead, whereas these seem to wedge into the bead and not completely fit down in it...
if that makes sense! If you look at the shot of the rear drives, you can almost see that the tire's sidewall doesn't touch the outer edge of the rim.
"If you build it, they will come"
East Coast Mini Truckers
Old 04-22-2012, 04:43 AM
CorbettTrailers's Avatar
CorbettTrailers CorbettTrailers is offline
CorbettTrailers is on a distinguished road
Hey Rod, Just a quick question. Are you gonna look closer at making the tires fit more properly or are you gonna just leave them the way they are? I did notice in the picture. Curious though if you wouldn't have mentioned it if it was really noticable. But Since we knew what to look for it stuck right out to me.
Nice build so far. I will be watching this to the end. Great job!
ECMT Members: Join your Group. Go to your username in the top right corner of the page and click on it. When your profile opens go down to group memberships, Click on East Coast Mini Truckers, The social group will open and scroll down And in the middle it you will see "Join Group" Click on it and then confirm that you REALLY wanna join.
[SIZE="2"]
Old 04-22-2012, 03:40 PM
Stepside's Avatar
Super Moderator
Default Re: Aeromax Daycab Dump 6x6 (Update: 4/01)
thanks for the comments guys. As for the tires, I think I will keep them as is. The thicker sidewall within the rim bead seems to make a tight seat and I believe I won't need to glue the tires, but we'll see.
I did some work this weekend on the dumpbox, looking to post some pics soon
Old 04-23-2012, 03:28 PM
Stepside's Avatar
Super Moderator
small update... got the front bulkhead made. turned out great, very happy with the results. Working on the cab protector & waiting on hardware to start assembling the box. still have the protective film on the aluminum!
