Old 03-31-2012, 10:41 PM
Madda Madda is offline
Default Re: 1/14 Grader Caterpillar 12F
Thanks for the pics, I wonder, how precise is that machine?
Old 04-01-2012, 11:13 AM
fuchs301's Avatar
fuchs301 fuchs301 is offline
fuchs301 is on a distinguished road
@Madda,
it is hard to give you an exact value for the precision, only one example: for the ball bearings I had to mill a hole with a diameter of 16mm. I used a two flute milling cutter with a diameter of 3mm and the result was a hole with dia 16mm +0,01 / -0,01 mm and it was perfect to press the ball bearing in it.
--- Chris
