Old 04-02-2012, 09:31 AM
carp carp is offline
Default Re: KOMATSU Excavator from Malaysia
nice work, it seems to be working very well with that industrial valve block in there, what sort of run times are you getting with it?
Old 04-02-2012, 02:42 PM
izzzul izzzul is offline
izzzul is on a distinguished road
Not sure if i understand you perfectly, on the clock, we hv been testing the hyd for about 3-4 hrs since the build, so it should be running smoother when the spool valve/seals/cylinders is 'soften/seasoned' i think, need more time to play with it, still got other build coming along too, limited time..this valve is used in small hyd machinery like small size forklift and mechanical assist tooling. it's reliable of course (big and heavy build block).. plan to boost up the pressure using 1.4 or 1.6cc hdy pump, same is size, just ratio-ing different.
Old 04-02-2012, 04:39 PM
He's wondering how long the battery last's, before recharching?
Cheer's, Neil
