Hello Azizul! Thanks for the reply and I'll be in touch with you soon I just need to find out how to send private mesage first...
If not mistaken, my industrial valve block allows me to auto divert/auto cut the hyd overpressure as there is a neutral line with-in the valve block itself that function to safeguard the valve, normally <5bar pressure only when any/all cylinders are in idle/holding state, without losing its position . And I make full control of throttle valve/aka hyd pump motor as to suit different force/job level....aka the speed for the movement..hope everything is fine with my design.. PS: I'm using 6mm X 4mm nylon tube for hyd lines, with gasket fitted compression screw nuts. Last edited by izzzul; 04-06-2012 at 05:56 AM. |
