Go Back   RC Truck and Construction > R/C Boats > Boat tech
Boat tech Tips/Tricks and info on all boats in here.
Old 04-12-2012, 05:22 PM
modelman modelman is offline
Default Re: Fiberglassing a Dumas Chris Craft boat?
Travis-I failed to mention the west resin doesn't sand very good. It gets really hard but tends to gum up unless you let it cure awhile. It likes heat if you need to sand it after setting overnight. I usually just waste a couple of pcs. of sandpaper to knock the top off and then it sands pretty good. Just remember not too much sanding. If you sand into the cloth then it will show up slightly.
Old 04-13-2012, 05:51 AM
Mrfish55 Mrfish55 is offline
Mrfish55 is on a distinguished road
Seal the hull with one coat of resin first(glass resin or West System epoxy) then when that is set cover it with 3/4 oz cloth ( not matt) and another coat of resin. What system you use will determine the whole process, west system epoxy is stronger and clearer, but given the scale of the model regular fiberglass resin will work, you will not be putting it on thick enough to notice any significant yellowing, the fiberglass cloth becomes invisible once saturated with resin but as was already mentioned be carefull not to sand into it or it will show, also IMO regular resin is easier to work with than the West epoxy, One other thing if you do go with regular fiberglass resin make sure you get unwaxed resin. Temperature and humidity will affect setting times so make sure to accurately measure the resin and catalyst, makes a big difference to how it sets. Nice boat, good luck with the project.
