Old 09-09-2010, 06:25 PM
Default Re: Bearings
Sealed bearings are not really sealed they have dust covers which do not keep out water. When we raced we used mini bearing greasers to push out the old grease and put in new. If the seal was tight against the outer and inner races to keep water out the bearing would have a lot of drag on the mating surfaces. Before you reply to this get out a bearing and hold the center and spin the out side if it spins free it can't be sealed to good. Rubber tight on metal will have some drag maybe not as much as a bushing. Don't get me wrong they use other materials to seal a bearing such as metal and fiber shield but it is not going to be a perfect seal.
Old 09-09-2010, 09:20 PM
FreddyGearDrive's Avatar
One of the beatiful things about the bushings,is there self oiling. The grease is permeated in the metal. As the bushing gets hot it releases the oil. Take a torche & heat one,& see what it does. Might look at bearings in a different light.
Like Travis,My trucks have the bejeesus geard out of them.don't need to worry about a little power draw spinning the drive line.
So here's a new question on this topic. Which is a better way to spend your money at the hobby shop,Gear reduction or bearings?
FGD
Old 09-09-2010, 09:33 PM
FGD
gearing baby , gearing , my 5900 in 3rd is almost as fast as stock set up in 1st I have a few bearings but only in the wheels but may change some day .
