Old 04-15-2012, 09:29 AM
Stefan Stefan is offline
Stefan is on a distinguished road
Default Re: Volvo G990 Grader
Hej Dan!
Yes, my intention was to build two of them, which I've also managed for most of the parts up till now. The calculation was that all the time for planning is better invested that way. The drive axles are a two piece pressed, or rather glued, construction. The axle proper is diameter 12 mm. The material used is stainless 1.4305 (which I think is called 303 in the states). I use this where no welding is needed, for the simple reason that it doesn't weld but is relatively easy to cut (achieving an acceptable surface). For parts to be welded I use 1.4301 (304).
Stefan
Tags
1:8, grader, volvo
