Old 04-20-2012, 06:04 AM
TRUCKMAKER's Avatar
Default Re: My Stretched globeliner
I learned that when you get to the point of having a lot of soldered joints near where your soldering you need to use heat sinks, in my case on the headache rack I used a bunch of vise grips because it was all I had at the time. If you use them put a very light pressure on the part, as the brass gets hot it gets soft, to much pressure and you'll leave a small indentations.
