Old 04-21-2012, 02:31 AM
picapiedra's Avatar
picapiedra picapiedra is offline
picapiedra is on a distinguished road
Default Re: New build. Yes another peterbilt tri-axle dump! small update 4/17/12
Congratulations for your work, the detail of bending the shaft'm fine but I imagine that the material is flexible, no?
Old 05-19-2012, 10:20 PM
ihbuilder's Avatar
how's this 1 coming along , Brian ? look FWD to some updates .
Old 05-26-2012, 02:55 PM
Brian in PA's Avatar
I'd rather be truckin'
Thanks for the comments guys. The lift axle bend is actually made form a piece of 1/2 solid steel rod that i heated and bent. I had turned it down to fir inside one of Ric's aluminum tamiya axles. i had cut about 1 inch off of each end than inserted the steel axle in side it.
Brian
Old 05-27-2012, 02:09 PM
Default Re: New build. peterbilt tri-axle dump! small update 5/27/12
OK here are some updated pics. I got my wheels and tanks from Steve! Thanks Steve, they fit great. I also got the rivets done. Enjoy and thanks for looking!
Brian
