John , I'm assuming your going to make a plate some what like the setup on the front steer axle of a truck . If you do not want to go to all the trouble making u-bolts ( would look scale ) You could make a top and bottom plate and use 4 bolts & nuts . If you have trouble with u - bolts let me know , It wouldn't take me long and they can hitch a ride with your other stuff
Thanx buddy, Big John
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. YOU WANTED THE BEST AND YOU GOT THE BEST THE HOTTEST BAND IN THE WORLD...KISS!!!! |
2-56 or 4-40 all thread or threaded pushrods can be bent to shape. I've used Sullivan threaded steel rods to make some u-bolts for a 1/8 scale boat trailer. I used the assorted double end threaded rod, cut and rethreaded as necessary prior to bending.
![]() Big John
