You can take out the potentiometer if you've got two 2.2k resistors, Put the resistors end to end , solder the middle wire from the pot to the center, and and end wire from the pot to each end of a resistor. They hold uP to moderate load I used to use them alot for robotics. Nice thing is if it does fry they are cheap and easy to come by
well the resistors are ordered does this trick work on all servo's I've just purchased some small servos which will hopefully be converted to screw drives to raise and lower the blade of the dozer
