Old 04-29-2012, 10:16 PM
Trucker47's Avatar
Trucker47 Trucker47 is offline
Trucker47 is on a distinguished road
Default Re: Let The Build Begin!
Espeefan - Thanks! Im actually just a gr 12 high school student couting the days until grad Hahaha yes it seems they are the cause of many delays, hahaha
So i just got a big part of my hydraulic system.
For the motor i went with a 740KV Thunder Tiger 36 Series Ripper outrunner.
Then i got a E-Flite 60 Amp Pro Brushless ESC:
I also got the ESC's that I will be using for the axle motors, they are Pololu 18v15 Digital Speed Controllers. Have a max output of 30a, input of 30v and are reasonably priced, plus they are small. I just hope that they hold up under the high draw setup.
Now that I have the motor for the pump I designed a belt reduction system using FingerTech Pulleys that will reduce the RPM -2.8x which will increase torque and keep my system pressure constant under load.
The housing
So If everything comes together like it should I hope to be finished to a point where I can hand it in, then over the summer and however long I have the model I can fix gliches, upgrade parts and put all the details on.
Thanks for reading,
Old 04-30-2012, 11:52 AM
Originally Posted by Trucker Al View Post
Chris,
Are those E-Flite 60 Amp Pro Brushless ESC's reversable? I don't think so...
Alan
That one is for the pump motor.
Reg
