Old 05-01-2012, 08:28 AM
Default Re: 5 stage hydraulic clyinders
I have some cad drawings I drew up and just got some tubing in yesterday. If I get some time this week I'll give my design a try. Another member suggested to me that the ram should extend at least 30'' for a dump trailer to get close to 60deg. Any thoughts or suggestions?
Can someone give me some info for the attachment and closed height dimension? I could go over to my friend's shop and check one of his 1:1 dumps though.
Old 05-01-2012, 08:57 AM
JAMMER JAMMER is offline
Steve the closed height should be about 5 inches and the attachments would be pins about 1/8 inch or less on the top and bottom. I was thinking a 1 inch lower tube and then a 7/8 3/4 5/8 1/2 3/8 and 1/4 with the 7/8 to 1/4 being the stages and 4 1/2 inches long would give you about 30 inches. This way if you wanted a shorter cylinder just subtract a stage or start with a smaller bottom tube and go up. The hole problem is the sealing of the stages, not to tight and not to loose. This is only a suggestion to the problem and I think I am going to give it a try either with O rings or packing or both. Ed
