Old 05-06-2012, 10:46 PM
Default Re: mining truck and dozer conversion. first atempt.
Great start on both project's! Look's like you're having fun with the build's.
Cheer's, Neil.
Old 05-07-2012, 08:42 AM
mack kid mack kid is offline
mack kid is on a distinguished road
I always thought of doing one of those coversions. like both. i like what you did with the dump box a lot of smart thinking going on there.
Waiting for Parts!
Old 05-07-2012, 05:19 PM
d4vew557 d4vew557 is offline
d4vew557 is on a distinguished road
A few more pictures of the screw drives
the drive mounted
just needed a small modification to the blade to get it to fit. I had to do a few mods to the servo aswell. The original mountings were chopped off and a 5mm hole drilled for the mounting pin to go through, the problem with this is the servos are so small with the pin through them there was no room for the electronics so the have been removed and will be fitted in the body of the dozer with just a wire running up to the motor in the servo .
