Old 09-11-2010, 07:18 PM
Snochaser's Avatar
Default Re: CAT 535C Grapple Skidder
Do any of you know of a continuous swivel I can use for the grapple so I can spin it 360 and not have an issue with hydraulic lines twisting?
Thanks Ben
Old 09-12-2010, 12:10 AM
DieselKid's Avatar
Have been following this build as a 'lurker' you might say for quite some time now, and was disappointed I didn't get to see it in person at Indy.
I couldn't help but chime in....
Phenomal fabricaton of an awesome machine.
And those Mashers are a perfect tire choice, spot on for the ag/industrial look! Our drivers haul quite a few loads out of Titan Tire in Bryan, OH and many times they sit in the shop while the trailers are being serviced....loaded with a mix of ag, forestry, and industrial tires and by far these tires you have from Pro-Line are the closest to any I've seen!
Nice work so far all around Ben, looking forward to more!
-Alex
Old 10-14-2010, 02:33 PM
Vanisle Vanisle is offline
Thanks Ben
I thought Leimbach sold one but from memory it was pretty expensive. DSTI makes some hydraulic slip rings. I have no idea what they cost or if they would work in this application.
http://www.dynamicsealing.com/gp_2-passage_unions.html
I have thought about how to make the swivel as well (for a long term skidder project of my own). I think you might be able to use some fins to turn the swivel housing with a hydro line into each side of the housing where the lines enter at an angle to push the fins with the fluid. Of course you would need some gears in there to do the actual turning and you would have to limit the rotation so your hoses to the grapple wouldn't get twisted. To do a true 360 degree swivel you would need to have a hydro slip ring for the grapple hoses.
Not sure how it could be done but one day maybe I'll give it a try.
Old 10-14-2010, 02:34 PM
Forgot to add, the skidder looks great!
Old 10-16-2010, 08:02 AM
FreddyGearDrive's Avatar
Man,This looks great! You called me the expert? If mine looks half this good,I'll be a happy Guy! Real nice job on the grapple!
Don't know how much room you have left,but the hydraulics will take up a bunch of it. Don't know if you have seen the mini pumps from stahl. It only took 15 months for me to get it. Guess ole-Ric babe is havin problems getting stuff from Germany. But it's very small & has a brushless motor(reversable) & you can set the rpm on it so your not making a bunch of heat running the pump wide open for nothing. Another draw back on the mini is the price!You can buy two regular pumps for the price of one mini.
If you want I'll post some pics of the differance between the two pumps.
Keep up the good work!
FGD
Old 10-16-2010, 08:22 AM
FGD
uncle freddy ,TTM has them in stock but , yea, the $ It seems the german dealers have them in stock
Ben , you did a fantastic job :thumbsup: .
IHSteve
