Old 06-11-2012, 02:11 PM
Default Re: Home made hydraulic cylinders?
Both ends are threaded and sealed with teflon tape. No soldering is used on these but I believe that is how it's done on the Vario machines.
Reg
Old 06-11-2012, 02:52 PM
carp carp is offline
so you put the tape on and just tighten the endcaps up? i will give it a try and see how i get on
Old 06-11-2012, 04:08 PM
Yes thats right. Pretty simple set-up really, you just have to make sure that you drill the hole for the fitting in the right place so that it doesn't interfear with the threads and also so that it lines up where you want when its tightened. I found that if it was a little out of line you could add more tape to the threads to correct it.
Madda, the thread cutter is just ground on the back side enough to allow it to fit in the hole, and the cutting edge is ground square instead of pointed.
Reg
