Old 07-26-2012, 01:56 PM
Stefan Stefan is offline
Stefan is on a distinguished road
Default Re: CAT 374D L
I see, its a bug and not a feature Well, in any case, the chain plates might dig in a millimeter or so (actually half a millimeter if you have the 6 mm pitched chains), but then the rollers start rolling on the land between the grooves and the wear rate should decrease.
Old 07-29-2012, 05:00 AM
Some progress with the undercarriage. The drive end is pretty much done but the front idler still needs to be done.
Old 07-29-2012, 10:05 AM
Sweet! You'll be digging in no time!
Old 07-29-2012, 02:15 PM
Madda Madda is offline
Madda is an unknown quantity at this point
Originally Posted by Hemi1966 View Post
Great work! Really impressive!
Do you have any more pictures of that motor cover or whatever is that called? You bent that radius or milled?
Old 07-31-2012, 11:43 AM
That's actually a U-profile that's machined that way.
Got the idler wheel and track tension mechanism done
Old 08-01-2012, 10:04 AM
Some progress
Old 08-01-2012, 10:14 AM
Lookin good Ari, at the rate you're going you'll have this done in a couple months.
Reg
