Old 09-16-2010, 03:08 AM
Default Re: My "office"
I'd like to try my hand at the excavator module, see if the 'collective bounce' is as sensitive simulated as it is actual? That small Komatsu hoe how I ran last Fall, I could have made it sing if I were outside of it with a radio control in my hands... being in the cab was quite new experience!
Simulator - animals in the road - if I saw a deer I'd floor it! would that be an automatic FAIL?! I hate them basturds, the amount of destruction they cause on the farm.
Night shift... I use to be a night owl when I was younger, but I get up with the sun now & don't last long after it goes down... flipping your clock every other week, is it something you ever get use to?
Does today's computer systems in these trks keep them from wheelie-ing on a stuck load? How do you clean out a frozen load... excavator?
Old 09-17-2010, 07:35 AM
ddc333 ddc333 is offline
ddc333 is on a distinguished road
Hi Joe
By the sounds of it Rick got it easy!!!!!!
I had 2 full 10 hr day inductions before I could even go on site. Once i started I spent 2 full weeks minimum 10 hr days in the class room doing all the procedures and going through all the rules and regulations. I got two work books about 40mm thick each .......... basically needed to know everything that was in them at the end of 2 weeks. We spent roughly about 4 hrs in a simulator and that was only to simulate emergency braking and if it came to the crunch you knew what you were doing.
After 2 weeks in the class room you then have to spend a minimum of 12 shifts so nearly a month with a trainer sitting next to you or in some cases following in a light vehicle until your deemed competent (At least one person I know took over 33 shifts before someone would pass her out)
After that your on your own till they move you from the 12hr roster to the 8hr and on to the 9 hr before you get back on the 12hr roster which is the best one to be on.
Joe the problem with the simulator is you can't "feel" with it if that makes any sense. I was the only one in the group I went through that had operated before and found the simulator hard because it I couldn't feel the response of the machine. What made it worse was I had come from a mechanical truck back ground to electric drive and there is a fair bit of difference between them.
Joe I reckon you would have no issues with the excavator simulator because of your radio control diggers. You operate without feeling the machine and this is what the simulator lacks. It is good for people that have never operated.
Kangaroos are an issue where we mine and at least one a day is to slow for the trucks.
Rick are your trucks speed limited ? Our maximum speed is 50km/hr. As far as i know we don't have an issue with over loads as they aim for 218t maximum payload. This something that Komatsu have put in place as a warranty measure. But that doesn't mean that trucks don't get over loaded just doesn't seem to restrict it's speed.
The emphasis is on the load unit operators not to overload the the trucks. But half the scales don't work properly or there is a problem with the computer systems or they just don't have scales. Also the loading units have scales so they go off those but without the truck scales there is nothing to check their accuracy against. The foreman often tells them throughout a shift how the loads are if they are to heavy or light or to slow turning trucks around and so on.
We use a 35t excavator to scrap out the bodies on the trucks when they get a build up in them or when they have to go to the work shop. Or the cannon of the water cart to blast it out if the little digger is unavailable
They don't like you to shake the trucks to much as it can cause issues and things break but if you have to do it reverse hard till you hit the wind row then break pull the hoist up all at once.
Night shift isn't that bad but all depends on what your doing and when you can have your break.
The computer system basically only records what the operator does so if you got hit the brakes hard it will record it as hard brake application and warnings go to dispatch and the foreman, same deal for over speeds.
Daniel
Old 10-25-2010, 06:08 PM
Rogue's Avatar
Rogue Rogue is offline
Rogue is on a distinguished road
Originally Posted by ddc333 View Post
........ I was the only one in the group I went through that had operated before and found the simulator hard because it I couldn't feel the response of the machine. What made it worse was I had come from a mechanical truck back ground to electric drive and there is a fair bit of difference between them.
I went through the same learning curve, as I came from a mechanical truck background. I still find myself reaching for that retarder handle sometimes
Out here where I am at, the **** antelope are what run rampant. They literally out number the human population in this state by 30,000 !!!
We have all sorts of wildlife on our site. Bald and Golden Eagles, antelope, prairie dogs, rattlesnakes, wild turkeys, and these big bull elk.There are 5 total, but you usually only catch these 3 at one time. All 5 together is a treat. The wander free on our reclaimed property. Needless to say, ALL wildlife has the right-of-way. We had to shut down one of our pits back in April, as we within 1 mile of a pair of nesting eagles that had hatchlings.
Yes, the 830e's are limited to 28mph. The 930ae's are good up to 35mph. While not as fast as the big trucks, the 830's are quicker to build speed, so it's gets to be a pain when they mix the two sizes on a run. The big trucks are slower when loaded and climbing a ramp, yet they all but push the small trucks coming down a ramp empty.
Our 830's are good for 285ton, before they go into limp mode. The 930's are good for 385. The shovel hands on my crew are typically consistent at keeping the trucks right in the 245-260 range.
WOW, our computer system is so stringent its not even funny. The shovel keeps track of loads and tons total per shift, and loads and total tons per each truck that he loaded that shift. The computer in the truck logs total loads, and tons moved per shift. Cycle times are also logged by both the trucks and shovels. We just finished up 3rd quarter, and with the weather conditions being ideal here, our three 4100 shovels averaged 2.6 million tons each per month for the quarter.
We too use a small excavator for cleaning beds. We also have a older CAT 988 with a quick-change on it that has a stinger attachment for cleaning beds. We appropriately call this the "Violator". They don't like us "brake-checking" when the boxes are up, but we do it. i've seen trunnions shear off, and hoist cylinder spike into the dirt. Worse yet, one will pierce the floor of the box.
I usually like to take my break 2/3 through shift. That way you only have 3-4 hours left, and you're done. But we don't always get to make the call, as it's up to dispatch.
Our system does everything but tell you if your socks don't match, or what's in your lunchbox that day..
Rick.--- I suffer from Wedicosis
My other truck is a Komatsu
