Old 08-05-2012, 05:17 AM
Madda Madda is offline
Madda is an unknown quantity at this point
Default Re: CAT 374D L
Are you making these rollers with mill or lathe? I know that feeling when you have to make manually same thing for numerous times. I once drilled manually over 1500 holes...
But the build is still very cool and yet fast.
What size screws are you using there?
Old 08-05-2012, 06:22 AM
Madda, those rollers will be made with lathe.
The screws are M2 steel ones. It was a quite job to make threads for all the 64 holes with three separate taps. The 2 mm tap doesn't take much to brake.
Old 08-08-2012, 12:27 PM
Finally got all of the carrier rollers done including the upper ones
