Go Back   RC Truck and Construction > RC Truck's Odds and Ends. > Die-Cast Conversions Tech.
Die-Cast Conversions Tech. The tricks of installing drive line and electrical components into die-cast models.
Old 08-05-2012, 05:27 AM
Claus's Avatar
Claus Claus is offline
Default Re: farmall 1468 tire removal question
Originally Posted by fhhhstix View Post
The outer wheels are just pressed on to the axle. Grab the outer wheels and start pulling and twisting at the same time.
This is incorrect, the duals on the 1466 and 1468 Precision tractors are held on by brass or plastic colletes. You need to remove the center of the dual then drive the collet off of the axle with a small punch. I have done several wheel changes myself.
Old 08-05-2012, 08:59 AM
Sorry but I just pulled the rims off the tractor. I guess I did not know there was a repair manual available for the "correct" way to do it.
Old 08-05-2012, 09:41 AM
Claus's Avatar
They usually won't come off just by pulling, that's all I'm saying. If they have the brass collets they are usually very tight.
