Old 08-24-2012, 07:12 PM
Default Re: track loader
The Body and tracks are plastic on the Carson loader. The rest is metal. Metal tracks are in the works.
Old 08-31-2012, 01:56 AM
ngward79's Avatar
ngward79 ngward79 is offline
ngward79 is on a distinguished road
Quick question for you, does the screw drive motors connect to the speed control or do they get connected straight to the receiver like a servo?
Old 08-31-2012, 06:14 AM
U will need four electronic speed controls to run the motors via rc radio.
Originally Posted by CustomRCmodels View Post
Howdy Scott
with what electronics did yours come ? or did you install your own ones ?
since this electronic set from Carson ( compact unit with lights and all ESC's ) just has been released , but I just haven't found enough info's about that one yet , since nobody seams to carry it . I just saw a fairly high price for that unit . something around 400 Euros ?
Guess a couple small ESC's for the drive-motors or even a nice Tamiya tank-DMD with some small Thor controllers for the spindle-drives should do the trick here .
No electronics came with mine at the time I got it. I am using a pair of dimension engineering 2x12 escs to run mine.
I did final find a sheet on this new electronic part but I can read German enough to understand it.
http://www.carson-modelsport.com/Com...heit_LR634.pdf
