Old 08-26-2012, 03:44 PM
Default Re: CAT 374D L
Once again Ari, you've excelled yourself. It looks stunning - When you taking orders
Technical question from a dumb *** ( me )
Shouldn't the super structure sit on a thrust bearing or can the bearing you fitted take the heavy load from above, ie side load??
Elliot.
Old 08-26-2012, 04:36 PM
Looks to me like you're just stalling off on building those track pads.
Looks great!
Old 08-27-2012, 10:15 AM
It's not a dumb question Elliot, I was thinking that myself but I think they will hold. If necesary I can attach bronce ring under the upper structure that will rotate over the ring gear. Those thrust bearings tends to be too high and they
Old 08-27-2012, 11:26 AM
CAT315C CAT315C is offline
CAT315C is on a distinguished road
Has bearings and ball dual layers also have roller bearings that may come to serve for the application.
Carlos
