Old 08-30-2012, 07:56 PM
Default Re: 2 shift or not 2 shift?
Maybe an R2 2 speed from RC4WD with a 4:1 gear reduction. I have that set up in a couple of trucks and it is a real smooth set up. You will still have 2 speeds and the trans should fit in the Wedico chassis with no problem. Plus this set up is almost bulletproof at an affordable price as well.
Your also close enough to come down for a visit and you can look at some parts in person to see what you might like before spending money on them. I have a few different trans on hand and some gear motors as well. You are more than welcome to come over and check them out.
Old 08-30-2012, 07:59 PM
Claus's Avatar
Claus Claus is offline
Thanks for the invitation Travis, might take you up on that.
