Old 08-31-2012, 12:30 AM
PROBUILDER1964 PROBUILDER1964 is offline
Banned
PROBUILDER1964 is on a distinguished road
Default Re: KW Daycab "Pipe Dream"
one trick that i like to do when adding new type fenders...is cut off the whole hood side right below the rivet line and all the way to where the hood meets the cab line...make a brand new one for it and make it a little taller than it needs to be. Then on the fender itself ..add a back plate to it (C/A) glue it...then later on when you go to attach the fender to the hood ..just bolt the fender to the hood side ! this also emanates the pain in the butt filling in of the fender to the hood thing and its really stronger !....then later you can carve out the inner part of the fender /hood area you dont need and trim the hood side to what ever height you wish.. It just gives the fender something to hold too...if the fender is just glued to the hood side with a little bondo here and there...it can easily crack or bust off ! just a thought ?
