fun , is it not
Finally got all track links done. I had to make a fixture for machining the other side and also for reaming the track pin holes.
It's hard to believe that I used almost 2 meters of 100x6 mm plate for the 200 links. I use to thing that factory made tracks are expensive but as I proceed with these they begin to feel cheaper and cheaper... I also started to make the track pads but didn't got very far before I broke my last 3mm radius cutter ![]() ![]() ![]() ![]()
Got some track pads done today
![]() I decited to make them wider than I originally thought. The machine looks much better with little wider tracks, they are now 80mm wide. ![]() ![]()
Ari, could you make me 156 of those for my Volvo?
Thanks in advance, Reg Oh, I will also need the links as well! HAHA! Just kidding... They look awesome! |
