Old 09-15-2012, 09:20 AM
Tamiya Cowboy's Avatar
Default Re: P R globeliner buildup
YOur doing good.. Auto body fine line does not work with Tamiya or any other model paint it is just to thin and if you get it to heavy it bleeds. If you want to redo it use tamiyas fine line it work great been using it for year I have not bleed threw issues it all. Next you can go to a body supply shop get some 1/16 fine line in any color you want and strip out your strips that should cover you bleed threw if is is not to bad pulse it really makes your strips look great. On the motor it will if but you have to use the right pnion from RC4WD 6 tooth short and you put a 1/4 spacer between the motor and the tranny. Now them Axial motors are long so you will have to change it I use Integy or Trinity 55 turns in all my trucks I am not a big fan on the 4 to 1 GRU when you get the same power and speed out of a 55 turn and a 6 tooth.
Paul W. "Tamiya Cowboy"
