Old 09-19-2010, 06:01 PM
derailed derailed is offline
derailed is on a distinguished road
Default Re: Metal brake.
i bought the same bender as that grizzly
i'm not crazy about the performance
metal must be very thin(soft) to bend properly
i use it to bend plastic sheet and thin aluminum
glenn
Old 09-20-2010, 03:18 PM
modelman modelman is offline
glenn
You have to use your brain a little when using these cheap products. Mine works fine for my purpose. I also use clamps to hold down the center and I can bend a perfect 90 on a pc. of steel 16-18" long. You can't expect a lot for $20+.
