The next step in the process was figuring out how to make the articulated portion of the loader work. As easy as the photos make it seem I actually spent a lot of time trying to figure out what would give me full travel and yet be out of the way and not require to much hacking of the body/chassis.
![]() Now came the tricky part, how to get power to the wheels. I am using Tamiya semi axles as they are a exact match width wise as the original axles. This was a serious multi step process with a lot of swearing and head scratching. Step 1: Mask and cut clearances for axle, the point of no return! Before ![]() After ![]() Step 2: Make brackets to hold the axles to the chassis ![]() Step 3: Lock the diffs-a nifty little trick-insert a 4th bevel gear and viola she is locked ![]() Step 4: Paint axles and brackets and assemble ![]() Step 5: Mount axle to chassis ![]() ![]() |
Once I got the rear axle in I worked on the motor and transmission. I made these aluminum motor mounts
![]() With motor mounted ![]() ![]() From there I moved to the front axle, I had to make alot of cuts to get it to fit but she did! ![]() ![]() Made some mounts for the axle and installed them ![]() ![]() From there I made a custom drive shaft and connected it to the axles ![]() ![]() From there I put it all back together sans cab ![]() |
Here is a quick video of the test run...still need to get use to the controls and get a smoother speed controller...but she is powerful.
http://www.youtube.com/watch?feature...&v=famTtbUEBJ4 |
Tags |
bruder, conversion, dirt, liebherr, loader |
