Old 10-02-2012, 07:50 PM
Default Re: RDS8000 Mixing Help Needed
Originally Posted by rc_farmer View Post
Remember to set your pump channel EPA to 0 (which may be on ch 7 or 8)
The off side of the switch is set to 0%, but the on side should be greater than 0%. Doesn't have to be 100%, although the higher the number the faster the rpm of the pump will be in relation to stick throw of the valve ch.
I use one battery to power everything in the model, including more than one esc. A power bar of some kind is the best way to power up more than one esc from one battery.
Yes, red wire of rx lead should be unplugged, don't want too much BEC current going to the rx.
Old 10-02-2012, 11:46 PM
rc_farmer's Avatar
Master Builder
I shouldnt have said must for the separate battery....., thanks Lil G
Giving up is not an option!!!
Rob
Old 10-03-2012, 02:32 PM
Cheers Rob.
One other point I'm confused about is this one and Tyler's reply seems to confirm the same...
Pump = Aux 1 (ch 7) or Aux 2 (ch 8)
Set the EPA on either of these two channel to 0
So both on & off side of the switch channel EPA must be set to 0 for the mix to work with the RDS8000 radio?
Old 10-03-2012, 03:08 PM
rockNmayhem's Avatar
Cheers Rob.
Joe you are correct in your understanding now. You have to set the end points both directions on channel 7 or 8, whichever you are using as you pump channel to absolute 0%.
Once under the mix channel selections you go in and set the adjustments there to the max speed or position you want them to be and you are done.
Now one other thing is that you have to set the stick points to opposites so if you you are pushing the right stick up the adjustment should be positive and when down the adjustment should be negative to keep the motor driving in the same direction.
This goes for the same left to right. You just have to figure out what direction your motor is turning and set them accordingly.
I will try to make a tutorial video tonight for you guys so it's easier to see rather than read.
Tyler
~Tyler~
RockSolidCustoms
Old 10-03-2012, 04:21 PM
Interesting..
The Spektrum programming, off is 0%, but on has to be greater than 0 or the pump won't activate with the mix. And adjusting Rate greater than 100% has no effect, the slave (or master) will only run as fast as it is originally set in the servo travel programming of the channel.
Tyler
The Spektrum is the same.
You raised a good question Tyler, food for thought.
Old 10-03-2012, 09:27 PM
rc_farmer's Avatar
Master Builder
3 heads working together......
Rob
