Old 10-05-2012, 11:06 PM
Default Re: CAT 963 Full Hydraulic Build
Originally Posted by rockNmayhem View Post
Everything on these cylinders are out of aluminum and the final product is pressed together for a tight seal. I have nothing soldered on but we will see how they hold up against the pressure that the pump is puttin out.
Tyler
It's gonna be a heck of mess, not if, but when it blows apart!
Red lock tite might hold it all together for a while.
The Leimbach cyl ends are screwed on & glued.
You might want to try the cyls in a tuppaware container to contain the fluid explosion!
Old 10-06-2012, 12:04 AM
Joe is right Ty . Trust me I tried it I was lucky to do an air test of about 60 PSI 1st . otherwise they look good .
Old 10-06-2012, 04:20 PM
rockNmayhem's Avatar
Ok, coming from you two I know I have a problem already. I am going to design cylinder number three now and make some ends that will thread on so I don't have to worry. I'd rather do it right the first time then clean up a mess. I'll get to cracking on some new cylinders later and make them threaded. I hooked up air to the cylinder and I was able to push it to 100lbs of pressure but my pump on a full battery is pushing 165psi.
I'll try to get some more ideas but thanks for the heads up.
Tyler
~Tyler~
RockSolidCustoms
