Old 10-23-2012, 07:59 PM
Default Re: 990 cat loader (Earl Shiebbed)
well it turns out the valves are the culprit I knew it would happen steel wearing on aluminum with piss poor tolerances . at least the filter will catch the particles till I get my valves finished . I also turned the pump around so the belt is at the back of the machine as opposed to between the main motor and pump motor . should be easier to change the belt now . No , no maple leaf on our hats here .
Old 10-24-2012, 04:09 PM
o-rings came in after lunch for the filter . so I took a few min and put oil in an gave er a go back in bizz now will not get a vid till this wknd in the rubber pit I'll have to tie up 75% of it's HP just to make it look like I'm workin it hard
Old 10-24-2012, 06:08 PM
Supermario's Avatar
Glad to hear she's back up and running. You must have brought it to a CAT dealer to get such a quick repair time
Mario
Old 11-18-2012, 09:34 PM
lil bit of me time today
got the front fenders and light post fabed up . they came out much better in brass then aluminium welded I may mill out my own lights . these look like poo
