Awesome work on the stick and your undercarriage! Speaking of track pads. How long are your track pads?
Do you know the actual size of a 900mm width track pad for a 374? Length wise? Is it the same between 374 and 390? Thanks Jeff |
![]() ![]() But seriously, I might cut them shorter later. I've seen pictures of 374 that has maybe over 1 meter wide pads I don't know the exact lenght of the pad, but mine are 20mm long.
Everything is looking like it's coming together nicely. As far as the track width; It would depend on what the machine is going to be working on. Narrow tracks shorter frames for hard rock where no flotation is needed.
I Know the 385 ( which I'm building (2)) are 900mm (36")and 750mm (30") I'm making my shoes @ 64.25mm x about 19-20 mm .75" . I read somewhere that the 390 is just a renumbered 385 with a few added HP , etc
I started to make the cylinders
