Old 10-28-2012, 09:13 PM
Jw.'s Avatar
Jw. Jw. is offline
Jw. is on a distinguished road
Default Re: 1/14 CAT 390D LME
Originally Posted by grumpygrady View Post
i have a few links about making sand molds to do what you need ,let me know if you want them ,
but the best way is doing lost wax and using a wax tree and casting thirty or more at one time in a investment mold ,
and by the way plaster of paris will cause a exploration of hot metal because you can't bake all of the water out of it .
I would appreciate those links very much I sorta skipped over sand molds because I thought the undercut on the track pad would be impossible to mold. I've looked into the lost wax and everyone says its an expensive process with all the equipment needed. I only thought about taking that route as a last resort if all other methods failed. We'll see if it ends up that way. As far as plaster of paris, I didn't know about the water issue. Is there any way around it? I was going to fire it in my kiln to dry it. I would think 1832 degrees Fahrenheit would be enough to dry it completely. I haven't found a lot of info on casting metal into ceramics and what Ive found. The info on the slurry mixture they used for plaster is always different or not very in depth.
Old 10-28-2012, 09:22 PM
Jw.'s Avatar
Jw. Jw. is offline
My first negative silicone mold attempt that I'll use to make a positive silicone. Them I'll use it to make my negative plaster mold. In the final third picture, the mold came out quite well except for a few bubbles around the bolts. This was a result from most likely not vacuum degassing the silicone before I poured. I would have except I have yet to make a vacuum chamber and get myself a pump. Those are on the list next.
Old 10-28-2012, 09:37 PM
Jw.'s Avatar
Jw. Jw. is offline
Second attempt was a failure again but I'm getting closer. Air bubbles all over and it cracked.
Third plaster mold attempt. Once again there were a few tiny bubbles in the silicone that can be seen as imperfections on the edge of the track pad.
Third time worked. Almost. Although it did not crack on me I still have a few air bubbles. Again I'm sure I can easily take care of those once I get my vacuum chamber built.
