Old 10-30-2012, 01:37 PM
janderson janderson is offline
Tamiya Rep
janderson will become famous soon enoughjanderson will become famous soon enough
Default Re: Stupid mfu that keeps shutting down
Originally Posted by rc_farmer View Post
2.4 will work with the MFU, u just have to make sure that ur settings are all centered when setting it up and go thru ur setup-motions slowly. I am using both the rds8000 and the 10g from airtronics will running dual-rates @ 100%, all functions works with just the sticks and no trim movement necessary.
I have talked a couple of guys thru on the futaba, but no personal experience with them.
I said it will not work well with 2.4. We (Tamiya) recommend a AM/FM Analog radio for true plug and play use.
If you choose to use a 2.4 you may find issues, as the MFU was not designed for use with 2.4 radios.
Just be aware...
