Old 11-03-2012, 03:08 PM
Supermario's Avatar
Default Re: Testing out new shocks
Originally Posted by Goose19 View Post
cool, i knew i recognized the name, couldnt rememeber from where tho.
whats the length and diameter of the springs alone? if you dont mind measuring?
thanks
Allen
They are 1/2" dia X 1" length ......oooppps , we're Canadian but I'm old
They are 12mm X 25mm......
After I sent you the link, I ended up ordering another set for my rig.
A set of four, out the door for fifty bucks, can't go wrong.
Mario
Old 11-03-2012, 03:19 PM
Supermario's Avatar
I know what your thinking Allen,
Ya, 1/2 shrink tube would slip over and then maybe a hair dryer on hot instead of a lighter or small torch. Could probably get it to shrink more evenly with a hair dryer?
Mario
Old 11-03-2012, 03:21 PM
Goose19's Avatar
Goose19 Goose19 is offline
Mario
i may be younger, but i speak both english and metric........does that mean im bilingual?
thanks mario, now if i could be the spring alone to put inside russ's air ride.
didnt see it in his store.
Old 11-03-2012, 04:09 PM
Supermario's Avatar
I've come across sites with various springs, can't think of it right now. I'll let ya know if I find it. Sorry, didn't realize you we're just looking for the spring
Mario
Old 06-04-2015, 12:47 AM
RoadFlyer's Avatar
RoadFlyer RoadFlyer is offline
RoadFlyer is on a distinguished road
I know this is an old post but thought I would give my 2 cents worth about these shocks. I bought some of these and put them on my Knight Hauler...looked great but I didn't like the stiffness of them. I guess if you are hauling really heavy loads they might be just what you need. I tried adjusting them all the way to a softer setting but still a little stiff. They do look good though. Still looking for something better that has a little more give to them for my highway runner.
DOUBLE THE TRAILERS...DOUBLE THE FUN...
Old 06-04-2015, 04:43 PM
Supermario's Avatar
Did you try them with the spring removed and only on the oil shock ?
Your right though, best use is for heavy loads. I haul my 40lbs excavator and lowboy. The springs turned up help keep the suspension from bottoming out.
The dump truck also has them because without, the stock suspension can't handle a load and drives around with axles on the rails.
