Old 11-06-2012, 12:04 PM
rc4ever rc4ever is offline
rc4ever is on a distinguished road
Default Re: geared motor
Thanks lilgiants,
So, do u think the 40rpm output speed geared motor will work? About the tires I have no luck to find a better n harder foam to handle the weight! Do u have any suggestion?
Old 11-06-2012, 02:34 PM
Wouldn't a 10 rpm gear motor driving an axle with a 3.75-1 gear ratio give you an output of about 2.6rpm?
I purchased some foam from an automotive upolstry shop and made my own inserts with it. It looks a little like carpet underlay but it's 2 inches thick. It works out great in my Euclid. I can haul a car battery in the box now and the tires stay put with no glue but it still has a little give for traction while empty. I can take a picture of the foam for you if you like.
Reg
Old 11-06-2012, 03:02 PM
Thanks reg, I'm more than happy to c the pic of the foam! please post it n tell me where to buy it? About the geared motor, what do u recommend? I've seen many of them on eBay but unsure which one I should go for
Thanks in advance
Leon
Old 11-06-2012, 07:29 PM
Reg
You're right! I don't know what I was thinking?! I should have divided, not multiply.
You'd need atleast 120rpm to achieve 32rpm wheel speed... 140rpm would be just over 37rpm.
Old 11-06-2012, 08:18 PM
Here are the pics of the foam that I bought. It cost me $15 for this piece so it's not that expensive. I used a bandsaw to cut the outside and a razor blade for the inside.
I think Joe is right about the rpm of the gear motor you need. Personally I wouldn't buy anything that was over 200rpm or it will be pretty fast. My skidder for example has 152rpm motors with a 2.6-1 axle and 7 3/4" tall tires and the speed it quite good.
Reg
