Old 11-06-2012, 02:33 PM
edwalsh18 edwalsh18 is offline
edwalsh18 is on a distinguished road
Default Re: bruder excavator conversions
Originally Posted by jetdog View Post
Hey bud have you found any more info on these conversions im just about to pull the trigger on an excavator from rc4wd but this interests me quite a bit
Sorry nothing yet. But i am still looking.
Old 11-28-2012, 04:27 PM
well it seems like this project has dragged on... i couldnt find the wood auger bits at all. recently spotted some on ebay and also some in harbor freight.
$6.99 free shipping
http://www.ebay.com/itm/Irwin-1-4-x-...item2a262b43a1
$15.99 minus 20% with coupon($12.79) + tax no shipping($13.91). i would buy 2 packs and use the 2 smaller ones on the excavator and the bigger ones for other stuff maybe
http://www.harborfreight.com/7-piece...set-68166.html
about $28 either way...
anyone know of any other place to get these?
Old 11-28-2012, 04:53 PM
so i did manage to convert the tower pro mg 995 servos to full rotation. at first was a pain but now it takes a few minutes. i am not great at soldering and didnt have a bunch of 2.2k ohm resistors(i think is what is needed) so i did it another way.
- removed the gears to get to the one with the pin on it
grabbed the gear with pin using pliers... turned on bench grinder...
NO MORE PIN!!! (took 10 seconds!! compared to the hour i spent
trying to use 2 pairs of pliers to remove them like i read on some website!!!!)
- cut the pot with a mini pair of bolt cutters, connected to rx, centered it and placed it back inside servo
all in all i was pleased with the results, they might creep a little but its okay. i thought i would have destroyed at least one but all that happened was i pulled a wire off the first servo's pot and successfully soldered it back on... first successful solder job for me! lol
since i bought 10 for $70 its a great deal. cant wait to see how they hold up when digging.
also while taking apart the excavator i destroyed every clip/pin whatever they are. my flat head screwdriver skills are horrible!! either that or bruder plastic gets a little brittle after being out in the sun. but its ok i will put it back together so it can come apart easily if needed.
i seen the way cdm is extending his boom/stick and reinforcing it. i like that idea, might try to do it also.
here:
http://rctruckandconstruction.com/sh...13&postcount=4
i was planning to reinforce the plastic with metal strap and metal tubing as sleeves but keeping the plastic outside. something easy and at my level. LEVEL 1!!!!
Old 12-05-2012, 05:19 PM
hows this for a bruder conversion???
https://www.youtube.com/watch?v=i-5q6RViDY0
