Old 11-07-2012, 03:06 PM
Supermario's Avatar
Default Re: 13 Axle big boy
Originally Posted by nutmag View Post
I'm going to do air bags I think i have found a way to make working air bags. No leaf springs just arms that go from frame back over the axle then to air bag. If my air bags work i should have the only working air ride truck out there that i have seen. Last of all are the size of the screws on a tamiya rail 2mm or 3mm?
The rail screws are 3mm. Not to burst your bubble but someone has been working on functional airbags. Once I find it, you can check it out.
Mario
Old 11-07-2012, 03:11 PM
Supermario's Avatar
Mario
I don't know how to send you the link but you can find on this site, under Vendors - it's. Rock solid customs. Check out the "custom air bag " thread. His name is Tyler, cool guy. I'm sure he can help ya out
Mario
Old 11-07-2012, 03:26 PM
nutmag nutmag is offline
nutmag is on a distinguished road
I know i looked at his and his our spring. I want real airbags and i need 26 airbags that would be over $300 in suspension.
Old 11-07-2012, 03:30 PM
Supermario's Avatar
Oooppps, sorry wrong thread.... I know I've seen one. The guy had tested them up to 120 psi for burst rating.... I will dig around and find....I'm stubborn that way
Mario
Old 11-07-2012, 04:00 PM
Supermario's Avatar
Nope. That was the proper thread. The pics with the airbags being tested under pressure have been deleted. I'm going to assume that the idea never panned out....so, I stand corrected. You CAN be the first to make a functioning airbag. Lol
Mario
Old 11-07-2012, 06:10 PM
My idea for the air bags is to make a wood pill like shape then plastic dip it till it is right thickness. They don't need to hold alot of psi 10-20 maybe 30. Then i will cut holes at top and bottom. Then use washers and some little aluminum post. to keep it cheep and simple.
Old 11-07-2012, 07:27 PM
Supermario's Avatar
I guess the challenge will be to maintain a uniform thickness so that the bag maintains the proper shape when pressurized and not bulge or deform to one direction or other? Or probably not a issue due to scale size and the direct vertical load they would have?
Happy building , good luck and keep us posted
Pics too please
Mario
Old 11-07-2012, 07:25 PM
Goose19's Avatar
Goose19 Goose19 is offline
how would to fill them? pneumatic robot stuff?
should be interesting to see
Old 11-07-2012, 07:37 PM
Supermario's Avatar
I have an suggestion maybe.
Unfortunately I am the proud owner of a blood pressure meter. I haven't taken it apart.... ( yet ). But it's very compact and can obviously generate some good positive pressure. It runs on 4 AA batteries.
Might be a good choice for a compressor? I paid 80 bucks here in Canada, I know there are cheaper versions.
Judging by the size of the whole unit, I'm sure the compressor would fit in a sleeper compartment.
Love the trailer idea by the way. I'm sure you've seen this video? Great example of rear steer trailers
http://www.youtube.com/watch?v=xGY9TDUAlFc&sns=em
Mario
Old 11-07-2012, 07:54 PM
Just found this site should help alot http://rackleybiltcustomtrailers.com...ble/index.html
and for pump there are some small air pumps out there
