Old 11-09-2012, 09:10 PM
Default Re: Starting trailer monday
what deck width are you going with ? for my scale 102" width I went with 3" outside to outside for the frame rails also . another factor is what axles are you using ? if a stock tamiya trailer axle , it will depend on how you plan to mount them . If it were me , I'd make my own setup (I did) do to the weight My rogers 55 ton is all steel and it weighs as much empty as what most would put on their stock trailer axles .
