Old 09-25-2010, 07:46 PM
dirtpusher9's Avatar
Moderator
Default Re: D9R and 463 pull scraper
Originally Posted by ihbuilder View Post
looks sweet Joe , Now get some dirt in it . Off the top of my head , restrict the flow to the apron . If that makes sense
IHSteve
That's a good idea Steve. Have to get some more fittings.
Old 09-25-2010, 09:01 PM
JAMMER JAMMER is offline
Thumbs up Re: D9R and 463 pull scraper
Joe that looks great and as far as your problem how about a valve in the with a servo to cut off or reduce the flow, it will go to the least resistance. Ed
Old 09-25-2010, 09:07 PM
On the cable scrapers I've run you pull on the lever and the door opens and then the ejector pushes forward. Then when you push the lever away the ejector moves fast to the rear before the door closes. You may need to put a needle valve that meters in one direction and free flows the opposite. So you may need two to dial in both functions. I have a small 4-1/4CY Soil Mover scraper that has a valve body in the lines to regulate the flows.
