Old 11-13-2012, 02:32 PM
krankillen krankillen is offline
krankillen is on a distinguished road
Default Re: tundra6x6 with Trailer!!
I was going to raise the gearbox. it started good .... but when the body was in place, then the gearbox was too high. redo, do it right! Now it starts to get complicated.
angle of the drive shaft became very sharp!!!!!
Old 11-13-2012, 02:40 PM
had to rout a new aluminum plate with a different angle. so I could lay down on the gearbox on the side.
Old 11-13-2012, 02:41 PM
I was going to use the original steering.
servo is moved from the side, in front of the gearbox instead.
Old 11-13-2012, 02:51 PM
is not so much images on the rear wheels. it will be rear-wheel steering. intend to use the original steering here. but had to remove it. I put a servo instead.
Old 11-13-2012, 02:55 PM
ordered a sound kit that would fit somewhere!!!
Old 11-13-2012, 02:59 PM
grind, grind, grind! a fifth wheel on the truck and a winch
Old 11-13-2012, 03:01 PM
Test assembly of body
took away the color of the shock absorbers.
