Old 11-13-2012, 02:40 PM
krankillen krankillen is offline
krankillen is on a distinguished road
Default Re: tundra6x6 with Trailer!!
had to rout a new aluminum plate with a different angle. so I could lay down on the gearbox on the side.
Old 11-13-2012, 02:41 PM
I was going to use the original steering.
servo is moved from the side, in front of the gearbox instead.
Old 11-13-2012, 02:51 PM
is not so much images on the rear wheels. it will be rear-wheel steering. intend to use the original steering here. but had to remove it. I put a servo instead.
Old 11-13-2012, 02:55 PM
ordered a sound kit that would fit somewhere!!!
Old 11-13-2012, 02:59 PM
grind, grind, grind! a fifth wheel on the truck and a winch
Old 11-13-2012, 03:01 PM
Test assembly of body
took away the color of the shock absorbers.
Old 11-13-2012, 03:05 PM
tested where the speakers will fit.
