Hello,
my newest project: Magirus Deutz 6x6 tipper, built since middle of the 1950s. Its scale 1:16 and i have construct it with the Robbe Cargo Series axles. Frame in aluminum, the drivers cab in copper sheet. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Best Regards Wolfgang
Best Regards Wolfgang To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Seilbagger; 11-16-2012 at 01:53 PM. |
Great start!
Cheer's, Neil. |
Best Regards Wolfgang To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Seilbagger; 11-17-2012 at 02:26 PM. |
Wolfgang your copper work is supurb.
![]() ![]() ![]() ![]() ![]() Big John
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. YOU WANTED THE BEST AND YOU GOT THE BEST THE HOTTEST BAND IN THE WORLD...KISS!!!! |
Best Regards Wolfgang To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Seilbagger; 11-20-2012 at 01:57 PM. |
You are a true craftsman. Amazing work.
wow excellent copper work! looks great!
Best Regards Wolfgang To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Seilbagger; 11-22-2012 at 02:38 PM. |
Hello,
i will build this truck as a dumper, here are the first pictures. Material is aluminum ![]() ![]() Best Regards Wolfgang
Best Regards Wolfgang To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Seilbagger; 11-23-2012 at 02:19 PM. |
Best Regards Wolfgang To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Nice progress!
I like the rock bed. Cheer's, Neil. |
Best Regards Wolfgang To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Seilbagger; 11-25-2012 at 11:28 AM. |
looking really good cant wait to see it painted. how are you going to make it dump? hydraulics or screw drive?
screw drive, i have a new idea to do it, motor in the back and the screw under the dumping body, not in the frame. I think this will be more powerful. Best Regards Wolfgang
Best Regards Wolfgang To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Seilbagger; 11-30-2012 at 10:50 AM. |
Hello all,
8mm threaded rod for the scrwe drive, lathed one side to 4 and the other to 5mm. To avoid damage of the screw, i used two hex nuts in the lathe. ![]() ![]() In this picture, there is only a 5mm screw drive, but its able to lift a 6 kg hammer laying in the front of the dumping body- ![]() One side of the dumping body: ![]() Best Regards Wolfgang
Best Regards Wolfgang To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Seilbagger; 12-04-2012 at 09:26 AM. |
Looking great!
It looks so rugged. |
Hello all,
the nut is made in brass ![]() ![]() and the first dumping test with a 6kg hammer https://www.youtube.com/watch?v=dnhX1-WvMuk Best Regards Wolfgang
Best Regards Wolfgang To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Seilbagger; 12-07-2012 at 07:43 AM. |
Hello all,
i've continued with this Dumper ![]() ![]() ![]() ![]() Magirus-212.jpg Magirus-213.jpg Magirus-214.jpg Magirus-220.jpg
Best Regards Wolfgang To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Seilbagger; 09-13-2014 at 02:54 PM. |
Nice craftmanship as always. That truck will be able to haul a lot of gravel
