1:1 Your Semi's,Trucks and Equipment Here is a spot to share your 1:1 that you drive and or operate. |
Cheer's, Neil. |
lol...hmm I'll check into it before I believe. Alot of guys now days faking one at least. Was up at peterbilt and kenworth the other looking at a truck and I asked about it and they told me most of them are dummy ones the get requested to put in and make them move like real. lol I'll check into this guys truck before I do.
All three work...if you watch him shift..even at night..the third stick is the low to direct..then he just uses the other two..which is you gear and the direct and overdrive select...on a standard roadranger select shifter knob you have the pull up button for low to direct and the slide button for you direct and overdrive on your 13 and 18 speeds..oh also on the 8ll
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. One Bus Stop Short Of The Short Bus... |
