Old 11-17-2012, 10:56 AM
Supermario's Avatar
Default Re: My stretched Pete
Keith, this rig turned out perfect for sure. I love it
Susan wants the same cab marker lights and no horns. Did you just add 2 more holes or did you have to map out and redo all the marker light holes?
And was it difficult to mount the air cleaner lights? I have a set from PMD and noticed there's too much silicone and the fit ain't the greatest. I'm scared to try and trim some of the silicone and not damage a wire
Mario
Old 11-17-2012, 12:59 PM
Kaf343's Avatar
Kaf343 Kaf343 is offline
Mario
Mario, thanks for the comment. I just filled in the air horn holes and then used the stock five holes for the lights and added two more evenly spaced between the two outside lights. As for the air cleaners I to had to trim some of the silicone, just had to go slow.
Good luck, I'm sure you'll be fine based on what I've seen of your rigs so far.
