could a just add a hydraulic pump to the set up instead of the air? or is ti different in the way it works?
You wont get proportional control your valve works either on or off like a switch and constant pumping against your cylinders with oil might not work, when it bottoms out it will blow the pipes off.
ya im taking off the air stuff putting back on the actuators, im going to have to rethink the hole set up. now is this stuff no good or is there something i can use them for? i got a truck project in the works
