Old 11-28-2012, 01:46 PM
rockNmayhem's Avatar
Default Re: Sealing Hydraulic Cylinders?
Originally Posted by ihbuilder View Post
Tyler , on a real 1 : O-rings with backup rings and a wiper seal . For what we do just an o-ring . Real 1's use chrome rods (polished) thats what you want to have . I use 304 L ss from online metals . From the mill it comes very smooth . Another issue could be your piston seals are too tight . Looking at you ram pics , def. too course . I should note , if your cap (gland) is cocked in the slightest way that will make it leak also .
Steve thankyou for the metal link. I'm glad I now have a metal number to go off of. I know how to rebuild a larger cylinder no problem with all the seals and rings but for this size I figured a sealing o-ring and a wiper was all I needed but I will back it down to one.
Do you also think I can still use the U-cup seals in the front or should I just stick with cutting an o-ring grove in the cap and leave it at that?
Also do you thread your caps on? I had the first ones pressed on but I'm designing another ram where the caps thread on with 12mm x 1.25 threads and am thinnking that might help some with sealing them up and keeping them straight.
Lemme know if there's anything else I can do differently as this is kicking my rear trying to get these cylinders built.
Thanks,
Tyler
~Tyler~
RockSolidCustoms
Old 11-28-2012, 02:00 PM
ihbuilder's Avatar
use an x ring IOW , the profile will look like an x instead of O I get them off McM. thats what they're called . yes my glands are threaded . Next 1's will bolt like Ari's . If I where you , I'd ditch the Alum. all together and go brass . much easier to work with for making cylinders . It hones nicer you can buy the tube (seamless) make the ends and silver solder them together . What grade alum are you using ? If your going to stay with alum. use 6061-T65 or 7075 - ? (Slipped my mind ) . you get a much better finish then hardware grade crap .
Old 12-01-2012, 05:53 PM
dirtpusher9's Avatar
Moderator
Tyler, you may be seeping by on the tubing side you may want to hone it and cross hatch it a little if it is too smooth.
I have some pics on my dozer thread page 8 or 9 that shows how I built my cylinders that may help with design.
Old 12-02-2012, 05:05 PM
Newcastle's Avatar
Newcastle Newcastle is offline
Newcastle is on a distinguished road
Do you have a website for McM. I'm interested in these seals. Thanks.
Old 12-02-2012, 05:52 PM
ihbuilder's Avatar
www.mcmaster.com
